Login Error
Close
Electrical Transformer
by DoItYourself Staff
The job of an electrical transformer is to transmit electric energy and power through the use of wires over long distances. They are considered passive because they transform a current fromone circuit into another.
How electric transformers work
The process of electrical transformation uses a trickle down method. For example the large outdoor electrical transformers break down voltage from 7,200 volt to 220-240 volts. The large appliances in your home like the oven or stove, the water heater, and the air conditioner require 220-240 volts to run properly. Smaller appliances like a computer, television, coffee maker or toaster run on 110-120 volts.
Small power-adapters that are used for cell phones, rechargeable power tools, and portable vacuum cleaners are also considered to be electrical transformers. They will break down the 220-240 volts that run through wall sockets to 9 or 14 volts, depending on the appliance needs.
On the other hand, automobile electrical transformers will power up your cell phone from 9 volts to 12 or 14 volts, as a car has much less electrical power.
Electrical transformer principles & types
  • A magnetic field is produced by an electric current
  • An alternating magnetic field produces voltage within a coil of wire
The most common types of electric transformers are control, current, power, isolation, automobile, high-voltage, dry type, and step-down.
 forum activity
