Login Error
Close
Electric Fence Energizer: Why You Don't Go Cheap
by DoItYourself Staff
Having a good quality electric fence energizer to run current through your electric fence is important. It does not matter if you are using an electric fence for a small pen or for a large farm, having the right energizer is essential. The reason for a quality energizer is for a stronger current. The stronger the current the better the shock. This includes a better current even when you have debris on the fence. An electric fence has to make a complete circuit in order to give your animals a shock. The weaker the shock, the less likely the animal will remember it. This is why you want to buy the best energizer you can. Trying to save money in this area will cost you in the long run. When you do not buy the best energizer you can, you are taking the change of more repairs. This is repairs not only to the energizer, but to your fence as well.
Repair Later
Buying a cheaper electric fence energizer will cause problems later. You have heard the term "you get what you pay for." This is true when it comes to buying an electric fence energizer. The only way a company can sell these cheaper is if the parts they use cost them very little. This, in turn, gives you a device that will need to be repaired or replaced sooner. If you buy an energizer that has just enough current to energize your fence, it will give the animals a weaker shock. The animals need to remember getting shocked by the fence. A weaker current will allow the animals to tear up the fence, and the repairs to the fence can get costly.
Better Circuit
An electric fence is only as good as the circuit it completes. The circuit of an electric fence is only as good as the electric fence energizer. The way a electric fence works is by completing a circuit that runs from the wire to the animal, out the animals feet into the ground, and back to the ground rods. If your energizer barley has enough current to run your fence and something gets in the way, your circuit well become weak. By spending a little extra money, your electric fence energizer gives you a more powerful current. With a more powerful current, the better the circuit will be even if grass or debris gets in the way.
Warranty
Having a good warranty on your electric fence energizer will save you money later. There are many reason for an energizer malfunction. One of the most common reasons is lighting, so spending a little extra money to get a warranty that covers lighting is a really good idea. The other reason for a good warranty is the outside elements. Though you may cover your energizer, it puts off heat. This causes condensation on your device and causes parts to go out.
It does not matter if you use your electric fence to keep animals in an area or use it to keep your animals off a fence, the better the energizer, the better the results will.
 forum activity
