Electric Grease Gun vs Pneumatic Grease Gun
An electric grease gun is a useful tool for those who operate heavy equipment and machinery. The gun injects heavy lubricating grease into machine parts. Most grease guns have a disposable grease cartridge which makes dispensing of grease easier. One feature that distinguishes the electric from pneumatic grease gun is the source of energy. Pneumatic guns operate on compressed air. While the electric gun has an electric power cord, the pneumatic version has an air hose attachment. Below are the pros and cons of each.
Pros of an Electric Grease Gun
These tools are more affordable than the pneumatic range. They can be used with ease on both light and heavy equipment. Electric guns do not generate as much noise as the pneumatic type. You do not need hearing protection while working with the tool. Due to their lightweight nature, which supports mobility, you can work more comfortably with electric powered grease guns. It also makes them more suitable for household use.
Cons of an Electric Grease Gun
Utilization of electric tools can be disrupted by power cuts. This causes work to stall which is an inconvenience. Electric powered guns are high maintenance tools. The component parts of the guns have a high wear and tear rate. This particularly applies to the motor which runs constantly when the workload is high. Overheating frequently occurs. This necessitates frequent replacement or repair. It makes electric grease guns high maintenance tools. Over time, maintenance costs add to the overall cost of the grease guns.
Pros of a Pneumatic Grease Gun
The high power output of pneumatic grease guns enables you to lubricate equipment more effectively. You also get to complete jobs quicker and with less energy. Pneumatic guns are also more dependable than the electric version. Since they’re powered by compressed air rather than electricity, you needn’t be troubled by power disruptions. It allows you to proceed with your work uninterrupted. The guns aren’t affected by moisture or water. It is possible to use a pneumatic grease gun in wet or rainy conditions unlike electric guns which would pose a risk due to electrocution. Running costs for pneumatic grease guns are lower than for the electric type. This adds to the cost-effectiveness of pneumatic guns in the long run. The pneumatic grease gun is also more durable than its electric counterpart. The well regulated air flow increases the life of the motor. It has fewer high wear parts which contribute to longevity.
Cons of a Pneumatic Grease Gun
Much noise is generated by the high powered pneumatic gun. This noise can be an aggravation especially if the tool is used within a domestic setting. It is necessary to wear hearing protection to prevent injuries to the ears. The hose attachment, if not handled well, can cause an accident. It may get entangled on an item or cause one to trip if not alert. This raises the safety risks of pneumatic guns. Although pneumatic grease guns are portable, you have to carry the compressor with you. Where large compressors are used, it is likely to cause physical strain.
