Login Error
Close
Electric vs Natural Gas Backup Generator
by DoItYourself Staff
A natural gas backup generator can be extremely useful to backup home electricity supply. Electricity contributes to a high level of our daily comfort. It enables the performance of many activities and operations of various household gadgets. Home generators are most often used to restore electricity when a power outage occurs. They can also provide energy at a lower cost for some home business projects. Any homeowner should consider acquiring a backup generator to restore electricity when necessary. An electric generator transforms mechanical energy into electricity. It may be fueled by gasoline or diesel. Below is a comparison of electric and natural gas generators.
Pros of Electric Generator
Electric generators are highly versatile. You can install one wherever you may be located. Installation is not dependent on the availability of specific infrastructure, as is the case with a natural gas model. Electric generators have high fuel efficiency. Less fuel is consumed for operations than those that are fueled by natural gas. Running costs are generally modest. This makes the electric generator a cost-effective gadget due to the savings made on energy costs. Electric generators are low maintenance devices, but they have a much longer life span than the natural gas model.
Cons
The unit is fairly expensive to acquire. This may act as a deterrent to purchase. However, the lower running and maintenance costs compared to the natural gas model may balance this out. Improper use of an electric generator is not without its risks to the user. A human error made during operations can easily cause an accident. Effects can be fatal. Electric generators may be regarded as lacking on the eco-friendly side. They produce carbon dioxide emissions, which contribute to environmental pollution. The diesel used to run the generator can cause unpleasant smelling emissions. This may make it somewhat uncomfortable for household occupants when the generator is in use.
Pros of Natural Gas Backup Generator
Natural gas generators don’t create pollution. Fewer emissions of sulfur, nitrogen and carbon dioxide occur with natural gas generators. Unlike the fuel used to power electric generators, natural gas doesn’t cause any discomfort due to bad-smelling emissions. It is generally regarded as a clean energy. This makes a natural gas fueled generator an eco-friendly choice.
Cons
Certain conditions must be met before you can install a natural gas model. If your neighborhood doesn’t have the necessary gas infrastructure, you may be unable to have this installed. Some models may require higher pressure of gas supply than the standard pressure available to your home. This necessitates adjustments by an engineer or other professional. Your existing gas meter may not accommodate the higher pressure necessary for the generator to function. It becomes necessary to install a separate meter for the generator. All these considerations must be factored in the budget. Natural gas costs more than the other fuels used to power home generators. This adds to your running costs. A natural gas powered generator requires regular maintenance to ensure that the unit works efficiently whenever needed. Failure to undertake regular maintenance can easily hamper efficiency and lead to the system breakdown.
 forum activity
