Login Error
Close
Electric vs Pneumatic Roofing Nailer
by DoItYourself Staff
If you plan on doing a lot of roofing projects, you may want to spend the money it costs to invest in a good roofing nailer, and the two common nailers are the electric and the pneumatic roofing nailer. Either roofing nailer you choose will save you time and hands. They both come with adjustable settings so you do not have to worry about damaging your roofing material.
Electric Roofing Nailer
An electric roofing nailer is a lot quieter than the pneumatic nailer. It does require an electrical extension cord and you will have to be very mindful of keeping it out of the way of others who may walk by and trip on it. An electric roofing nailer is heavier than a pneumatic one since it has its own attached power supply. Also it has its own depth reader and guide to drive straight nails.
The pneumatic roofing nailer is the one professional roofing contractors use the most. It is a bit noisier than an electric roofing nailer because of the air compressor and you have to drag the air hose around with you. The pneumatic roofing nailer does have a nail driving force from 70 to one 120 pounds psi. A pneumatic roofing nailer is more challenging to use in areas such as under an eave or around chimneys.
 forum activity
