Login Error
Close
Electrical Problems: 3 Common Solutions
by DoItYourself Staff
For most people, solving electrical problems are a daunting task. Typically with electricity, the poblem is larger than it may seem, however, these minor problems can usually be fixed quite simply.
1. An Appliance Stops Working
If an electrical appliance stops working, check the power supply. If other appliances are working use a mains tester to check that there is power in the socket. No power in the socket means the fuse has blown or the circuit breaker has tripped. If there is power the appliance is at fault.
2. Smell of Hot Plastic
The smell of hot plastic should not be ignored. Find out where the smell is coming from. If it is from a plug or socket the most common cause is a wiring problem. Check that all terminals in the plug and socket are screwed tight. The heat is usually caused by electricity arcing across a gap.
3. No Power in the House
Check that the main fuse has not blown or the main circuit breaker has not tripped. Check to see if your neighbors have power. It could be a general outage.
If a fuse blows or a circuit breaker trips try to discover the cause before you repair it or it will blow again.
 forum activity
