Login Error
Close
Electrical Retrofitting How To: Wiring Maintenance Tips
by DoItYourself Staff
When you do electrical retrofitting you also need to know the how to wiring installation and maintenance procedures. This article will give you tips and guides on electrical retrofitting. Once you follow these simple instructions you will be assured of a safe installation process and lesser time and effort in wiring.
Tools and Materials Needed:
  • Cables-two wire and three wire
  • Switch boxes and switch
  • Screwdriver
  • Extra-Long bit
  • Conduit
  • Draw wire or tape
  • Outlet boxes
  • Electrical tape
  • Drill approx. 1/4 inch
  • Cable connectors
  • Pigtails
  • Different types of saw – drywall or keyhole, circular saw
  • Madison hangers
  • Drywall tape
  • Cable protector plates
  • Side cutter pliers
  • Wire-nuts
  • Chisel
  • Receptacles or container for the items
  • Brace
  • Ripping bar
  • Wire
  • Neon Tester
  • Stud Finder
  • Hammer
  • Spackling paste to fill the holes
Step 1 – Turn off all Power
In every electrical retrofitting and how to wiring installation, it is common protocol to turn off the power. You may disengage the fuse or spree the breaker that you will work on in your repair board. Check the power if it was indeed turned off using the neon tester. If you feel wary that there may still be some electricity left, take away both the main fuse and breaker. Please be reminded that doing this will eradicate all power in the house.
It is also important to follow this simple protocol to avoid any electrical accidents that may become worst.
Step 2 – Look for the Coded Electrical Wires
To prevent any wiring errors, the electrical wires were made with matching color codes for this purpose. White wires are connected to a respective white wire or to a chrome terminal screw found on the switches and receptacles. There are wiring devices which have a back wire feature wherein the end of a bare wire is pressed onto spring grip holes and are labeled as to where the color coded wires connect to each hole.
Black wire cables are for switches though there are times when the cable must be extended the white wire may become the black wire instead. To prevent any wiring blunder, the white wire should be covered in black.
Also remember the standard gauge wiring that you can use to aide you what type of wiring thickness you will need. Do make sure to use uniform thickness even in extended wiring circuit.
Step 3 – Study the Wiring Diagram
This may sound like a cliché, but it is indeed important in how to wiring that you have a grasp of the wirings. Thus, it is indeed important that you learn the wiring diagram. This will equip you with knowledge on the basic principle of how wiring should be. You can also look for an electrical self-help book for easy reference to honing your craft and how wiring must be dealt with.
Keyword: electrical sub panel
Article Topic (Meta Title): Troubleshooting Common Electrical Sub Panel Problems
Title: Troubleshooting Common Electrical Subpanel Problems
Article Type: 5- Feature - Informational
Team Manager: Stewart, Justin.
Related Keywords:
Site Path Location: How-To Information >> Electrical and Electronics >> Wiring Projects >> Electrical Tools and Supplies
Article Length: 500 words
Notes:
Editorial Notes: You don't actually provide many helpful tips for troubleshooting. In troubleshooting articles, you should discuss common problems the reader may encounter. Give tips on how they recognize the problem. If they can do the repair, you may provide a very brief explanation of what they will need to do so. Please make this article more practical and helpful. Thanks.
 forum activity
