Login Error
Close
Electronic Fluorescent Ballast Advantages
by DoItYourself Staff
Electronic Fluorescent Ballast is one of the best lightening systems used for a variety of applications.
Higher Efficiency
It generate efficiency 15% to 20% higher, which is very economical to use.
Better Design and Control
You can easily tune output/watt ratio based on the requirement.
The two ranges of ballasts available:
  1. Low light output ballasts (LLO) intakes low illumination which is used for less energy consumption applications.
  2. High light output ballasts (HLO) intakes high illumination which can deliver three levels of higher output.
Light in Weight
The coil construction is very simple and their core is very light in weight.
Quite Working
All type of ballast core and coil generate a humming sound, whereas electronic fluorescent ballast does not “hum” at any case.
High Power Generator
Usually magnetic ballast can drive two lamps but electronic type ballast can drive up to four lamps with same input energy.
End of Life Detector
A T5 type of lamp (or lesser diameter lamps) is provided to detect before the ends dim off fully. It shuts off automatically avoiding the sockets to melt down.
Electronic Fluorescent Ballasts are always preferred with all these benefits.
 forum activity
