Login Error
Close
Elements of a Wireless Home Security Alarm System
by DoItYourself Staff
Alarm home security system wireless elements are easy to install without paying a professional. Expansion of your security system  is also simple to accomplish. A wireless alarm system is mobile so if you sell your home you can take it with you.
Wireless Alarm System Main Elements
  • Control panel
  • Keypad
  • Siren
  • Sensors
Where Should the Control Panel Go?
Place the control panel in a concealed area in your home where no one interferes with it. The control panel processes the function of all the system’s elements.
Installing the Wireless Keypad
The keypad is installed on a wall close to where you enter and exit your home. Easy accessibility ensures that you can quickly arm or disarm the alarm system.
Wireless Sirens
You can hide the siren if you our concern about the appearance of your property. Some people prefer to leave the siren visible so it acts as a deterrent to intruders. Whatever you choose be sure to place it high so you can reduce the chance of tampering.
Sensors
Make sure all doors and windows are equipped with sensors. A delay door sensor is attached to the door that is used the most in the home. Install passive infrared (PIR) sensors in all rooms of your home to detect any activity.
Exanding Your Home Security System
You may decide to expand your security system by including the following elements.
  • Sensors for the garage or shed
  • Smoke alarms
  • Carbon monoxide detectors
Using Your System
Program a user code and the elements of your system into the keypad. Check the instructions for the system on how to program the elements since each system is different.
Maintaing Your Home Security System
Test your home security system wireless elements after installation and periodically over time to know that the elements are working properly. Each sensor should trigger the alarm if it is disturbed.
Additional Home Security System Wireless Elements
  • Broken glass detectors let the homeowner know when a break-in occurs through a window or door.
  • Panic button tells the system to automatically dial for help when pushed. The system calls any number that you programmed into it in case of an emergency.
  • Pressure mat is placed under any rug or outside mat to detect and alert the homeowner of an unknown presence.
 forum activity
