Login Error
Close
Eliminating Pet Odors: How to Keep Your Rabbit Cage Smelling Fresh
by DoItYourself Staff
Eliminating pet odors is one of the most important parts of a pet owner's job. When you own a rabbit, you might find that the cage does not smell pleasant after a while. Here are the basics of how to keep your rabbit cage smelling fresh.
Litter
Rabbits can be litter trained. If you want to keep your cage smelling good, you need to put a litter box in the cage with them. They will get in the habit of using the litter, and then you can scoop it out afterwards. If you do this frequently, you will be much more successful in trying to eliminate the odor.
Clean Frequently
In addition to cleaning out the litter, you should also get in the habit of cleaning the cage regularly. You do not want to use any chemicals that can hurt your rabbits. If you can use soap and water, this is most likely going to be your best bet. You should try to clean out your cage at least once a week if not more frequently. In order to neutralize the smell, you can also utilize a mixture of one part vinegar and one part warm water.
 forum activity
