Login Error
Close
Enclosing a Carport: 5 Mistakes to Avoid
by DoItYourself Staff
Enclosing a carport is a great way to convert it into a usable room in your house. There are, however, a number of common mistakes which you can avoid if you know exactly what to look out for. By avoiding these common mistakes, you can find a way of quickly and easily installing an enclosed carport. When enclosing a carport you are turning a wasted area into a functional room which can be used for a variety of different purposes, such as a game room or a family room.
Mistake 1 - Not Cleaning the Floor
A very common mistake for anybody enclosing their carport is not to clean the floor. You must clean the floor of your carport off before starting work on it. At the very least, not cleaning the floor will waste a lot of time during the project.
Mistake 2 - Not Building a Concrete Pad
If your carport isn't already built on a concrete pad, you will need to excavate the area and make one from scratch. The concrete pad will be the foundation for your building. It's important that the concrete pad is perfectly level, as this will make your construction project much easier.
When laying a concrete pad you should excavate the area, and then use wooden boards to create a frame which will contain the concrete as it dries. This can then be held in place using stakes which are hammered down into the ground.
If you do already have a concrete pad, you must check that it is thick enough to support your new structure. If it's not, you may have to excavate it anyway.
Mistake 3 - Not Using Marine Grade Plywood
The plywood used to cover the outside of the structure must be exterior grade plywood. This will ensure that it won't warp or become damaged due to damp or moist conditions. A very common mistake is when people use standard interior grade plywood outside. This will only last until it rains or gets damp. As soon as normal plywood gets damp it will bend, warp and delaminate.
The plywood must be fixed around the frame before the wall covering of choice is applied. This includes if you're using siding, as the plywood will provide extra strength and durability to the structure.
Mistake 4 - Not Adding Enough Electrical Outlets
If you are wiring any electrical outlets into the new building, you will need to connect these before you hang the drywall inside of the building. This will ensure that the electrical outlets are flush with the wall and look as professional as possible. It's a good idea to plan and add these outlets now while the walls are bare.
Mistake 5 - Not Doing Enough Planning
The most common mistake that people can make when enclosing a carport is not planning properly. Planning should help to ensure that you are getting everything that you want. This isn't the type of project that you can hope to guess and guide your way through. You must do plenty of planning because measurements here are critical.
 forum activity
