Energy Saving Tips: Refridgerator Use
Energy saving tips are important because they help reduce our “carbon footprint.” Our carbon footprint is the amount of energy and waste we produce. One of the most common sources of high energy costs are refrigerators. They are very common and finding ways to keep the costs down are important, here are some easy ways to implement energy saving tips for refrigerators:
Proper Usage
If you implement minor changes in your daily habits and usage, you can save a lot of money on your energy bill. The savings may even be more than you thought would be possible. There are a few minor things you can do to cut down your bill:
- Thaw the frozen food taken out from the freezer by putting it in the refrigerator. This will help in improving the cooling in the refrigerator.
- Do not use the top shelf because items placed there prevent the free flow of air thereby making the compressor work harder.
- Do not open the doors of the refrigerator unless needed.
- Ensure that the refrigerator is full, but it should not be overloaded since that prevents the circulation of air inside the refrigerator.
- Fill up the empty space inside the freezer with water bags. Once they are frozen, they will keep the freezer cold.
- Cover all the food items and liquids put in the refrigerator. This prevents humidity.
- Do not put hot food or liquids in the refrigerator. Allow them to cool down to the room temperature before placing them inside the refrigerator.
- Organize your refrigerator well so that you do not have to keep the doors open for a long time to look for them.
Following the Technical Specifications
It is always good to pay attention to the working of the refrigerator and keep all its parts clean.
- Set the refrigerator at an appropriate temperature, it’s a good idea to keep the refrigerator temperature at 38 to 41 F and the freezer at 0-3 F
- Keep the condenser coils located at the back or the bottom of the refrigerator clean. Vacuum them regularly so that the compressor does not have to work hard to get rid of the hot air.
- Place it away from the direct sunlight and away from heat sources like stoves or ovens.
- Check the insulation in the refrigerator walls and replace any substandard insulation.
- Check the gasket on the refrigerator and see if the doors are properly sealed when closed. This will prevent air leakage and keep the refrigerator cold.
- Clean the gasket if it does not close properly or lubricate it.
By Using the Right Model
There are hundreds of refrigerator designs available. Talk with your energy company to know what it can offer in terms of energy saving and reducing utility bills. They might offer a low cost program to make your house more energy efficient, clean and green. Avoid refrigerators with built in ice makers or the ones with through the door water dispenser because they are energy guzzlers. Pick out your refrigerator and keep in mind that you should:
- Use a bottom-freezer refrigerator. Apart from offering a better design and convenience, these models are the most energy efficient too.
- A refrigerator consumes about 20% of the household energy and therefore you can consider replacing an old model with a new efficient model with the Energy Star Label.
- Make sure that the refrigerator size suits your requirements. A bigger refrigerator consumes more energy for obvious reasons and a smaller one will become overloaded if the usage is more. Strike a balance between the two.
