Login Error
Close
Energy-Saving Tips for Home Lighting
by DoItYourself Staff
If you are looking for some energy-saving tips regarding your home lighting, you should start with energy-efficient bulbs. You can also reduce daytime light usage by adding a south-facing window or tubular skylight. Also observe the simple method of keeping lights off when you are not using the space.
Energy Star Lights
Considering that light bulb usage makes up about 20 percent of the average electrical bill, you may find switching light bulbs a reasonable measure. Switching to light bulbs rated by Energy Star can save money and energy every month. Pay special attention to lights in the kitchen, living room or dining room, as well as commonly used floor lamps and outdoor porch lights because these typically receive the most use.
Tubular Skylights
Collections of energy-saving tips often urge you to use more natural light. Although it won’t help during the night, a tubular skylight can help you take advantage of the sun's light. It can illuminate a bathroom or other room that does not receive much natural light during the day. If you have to turn the light on in a room during the daytime, consider installing this fixture to save energy.
Old-Fashioned Method
Simple but effective, turning off lights in rooms when you don't need them is another way to reduce energy use and save money on the monthly electrical bill.
These are just a few energy-saving tips to help you reduce or modify your home lighting use. Saving energy does not have to be difficult or expensive.
 forum activity
