Login Error
Close
Epoxy Floor Paint Chips
by DoItYourself Staff
If you are thinking about putting in a new floor for your garage, laundry room or showroom floor, epoxy floor paint may come into play. While you can opt for a solid coating of epoxy paint, chips can help provide a more unique look to the surface. The chips help to break up the solid floors by adding a small splash of color even if the color is black. Working with these chips is not hard to do, and they can be great design additives to consider. Here is some general information about them.
Chips in Kits
Most of the time you will find paint chips in full epoxy flooring paint kits. Within this kit, you will find everything you need to make an epoxy floor. If you need to buy the chips on their own, you can easily find them at a home improvement store.
Choosing the Chip Colors
While most epoxy paint chips come in gray, black, or a shade of brown, you can get them in just about any color. If you feel like adding a sparkle to your floors, consider a reflective set of chips in a metallic color. That idea is great for showrooms where lighting is essential.
Installing the Chips
You can put the paint chips down while you make the floors. This is simply a matter of following the instructions in the kit and sprinkling the chips around when the time comes. At the end of the project, you will have a one-of-a-kind floor that will last many years.
 forum activity
