Login Error
Close
Epoxy Grout vs. Sanded Grout
by DoItYourself Staff
Epoxy grout is one of three common materials used to grout. Grout is the visible white or greyish material that seals the space between floor and wall tiles. Some grout is water resistant and other types are very porous. Consider the following fundamental differences between epoxy and sanded grout before selecting which type is best for you.
Epoxy Grout
This type of grout is made from epoxy resin. There is also a filler powder that is combined with the resin. This combination makes the grout hard and durable. Epoxy is great for use in high traffic areas because it resists all sorts of stains. While this type of grout has so many different benefits, it is really difficult to install in between tiles and it is hard to apply where there is a slope in the ground.
Sanded Grout
This is a product that is frequently used in home installations of tile. It is used when the gap between the adjacent tiles is at least 1/16". Sanded grout is made with a mixture of sand. Because of the sand, it adds much more strength to the grout line and the tile when applied. It is easy to install and can come in a variety of colors.
 forum activity
