Login Error
Close
Essential Home Upholstery Cleaning Supplies
by DoItYourself Staff
Upholstery can last for many years if you use the right upholstery cleaning supplies to keep it fresh and looking new. Here are some items that you will want to keep on hand for upkeep.
1 - Vacuum Cleaner
You will want to clean dust and loose debris from your upholstery by vacuuming upholstery covered furniture each week and window coverings every other month. It is especially important to vacuum seating areas as they are used most often. Dust and dirt can be ground into the upholstery if it is not cleaned regularly, which will make it harder to remove later.
2 - Stain Remover
Remove a spill or stain as soon as possible. Keep a spot and stain remover handy at all times, along with a clean rag. Before you need to use it, test the remover in an inconspicuous area to be sure it doesn't fade your upholstery. When you do need to use it, do not rub the upholstery, but just dab it. Rubbing the upholstery will cause it to become damaged.
 forum activity
