Login Error
Close
Essential Panic Room Supplies
by DoItYourself Staff
Once you have had your panic room built and fully equipped with the necessary features including vault-grade lock, steel reinforced walls, video monitoring system and a secure phone line, it is time to stock with supplies. There are some essentials, though. Forgetting them could be disastrous should you ever have to use your panic room in an emergency.
  • First and foremost, your panic room should be stocked with plenty of bottled water and non-perishable foods. You don’t know how long you will be inside, so you don’t want to take any chances. Several days worth it advisable.
  • Medications should be stored inside as well. If anyone in your family needs them for their survival, not to have them on hand would offset the value of the panic room.
  • A first aid kit is also something to keep on hand. Should any accident happen, you will want one of these around.
  • A panic room is designed to keep intruders out and your family safe. Should the unthinkable happen and the safety be comprised, having a firearm inside could very well protect you and your family from harm.
Having the essential supplies stocked in your panic room is one of the ways it can help to guarantee your safety in the event that you ever need to use it.
 forum activity
