Estimating Garage Door Installation Costs
To estimate the cost of your garage door installation, you need to keep in mind the size and style of garage door you wish to purchase. If considering doing the work yourself, you will also need to compare the labor costs of a professional against the any costs you might incur.
Professional Installation Costs with Door Purchase
The larger and sturdier the garage door, the more expensive the installation will be. An average-sized simple aluminum door might cost around $500 installed, while a steel door of the same size might cost closer to $1000. Insulated doors will be higher still.
These costs include the disposal of your old garage door.
Professional Installation Costs without Door Purchase
If you already own a garage door and simply need it to be installed by a professional, you can expect to pay between $250 and $500.
This price will likely include the disposal of your old garage door.
Do-It-Yourself Installation Costs
It may be possible to install your garage door for only the cost of the door itself. However, it is important to consider costs you could incur when doing the work yourself.
Do you have all the necessary tools for the job? If not, will you need to purchase them?
Can you leave your old door by your curb, or will you need to pay someone to take it away?
These are simply a few of the most important factors to consider when estimating garage door installation costs.
