Estimating the Cost to Add a Bathroom in a Basement
If you intend to add a bathroom in the basement, many of the costs associated with the installation are the same as if you were adding a bathroom on an upper level. However, due to the presence of the concrete foundation, running the water lines and providing drainage require a different process. Before you begin, make a cost estimation of the project to set a budget and give yourself an idea of what the job entails. If you’re building the bathroom from scratch, many elements are involved including framing, plumbing, wiring, cabinetry, flooring, drywall and finishing. Depending on the materials you use, there is an enormous range of potential costs. The initial estimate you come up with will directly influence your budget and hopefully convince you to stick with it.
Common Bathroom Addition Costs
While there are some notable differences when installing a basement bathroom, certain basic elements do not change no matter what. Start your cost estimation with the common costs, purchase the materials and have them ready to go. These include the framing of the walls and drywall. Determine the number of walls and board feet of lumber needed to frame them. Find the area of the walls and estimate the cost for the necessary green board, vinyl drywall tape, joint compound and installation hardware.
Move on to the wiring. Estimate the number of outlets, lights and switches, including their appropriate boxes and faceplates, and factor in those costs. Add to that any additional circuit breakers and all of the 12 and 14 gauge wiring necessary.
Fixtures and Flooring
Depending on the size of the bathroom, it may or may not have a shower and/or tub. It will, however, have a toilet and a sink. Factor into your budget the cost of the necessary fixtures including a shower or tub if included. If you are adding cabinetry, consider the cost of a pre-built variety or the raw lumber. You have several options for flooring, from ceramic tile to slate, granite, linoleum or some other synthetic product. Determine the area of the floor, decide on a material and add those costs to the mix.
Special Costs for a Basement Bathroom
Because you have a thick concrete slab as a floor, running drainpipes and water lines can get very costly. If you choose to go the conventional route, you’ll have to dig into the concrete and tap in to the main drain line for the home as well as run water to the fixtures. As an option, there are macerating systems which incorporate an above-floor drainage system which is cleverly concealed. A macerating drain system is equipped to handle the drainage for the sink, toilet and shower if present. It is a good, cost effective alternative to digging into the foundation and/or running a connection to the main drain.
With the main costs for the basement bathroom estimated, you can finalize the budget, making any necessary adjustments. Don’t forget the cost of primer and paint or some other wall decor, light fixtures and all of the little things that make a bathroom complete.
