Login Error
Close
Ethanol Fireplace Efficiency Facts
by DoItYourself Staff
As its name implies, an ethanol fireplace burns a natural element called ethanol that is derived from plants. You might have heard a lot about ethanol fireplaces lately, as they are gaining favor as a green alternative to traditional fireplaces. But aside from the hype, you may have questions want more specific facts before investing in an ethanol fireplace: how efficient is it really as a heating system? And what’s the cost-benefit ratio? Take a look at this fact guide to learn the answers to some of these questions.
Fact 1: Money Matters
If you are looking for a great way to save money, an ethanol fireplace is a good way to do it. You save money on gas costs, and ethanol is a cheap and readily available alternative that you can buy in quantities according to how much you need at a given time.
Fact 2: Heating Efficiency
An ethanol fireplace is an effective way to heat your home in winter, because it keeps the heat in the room, while a traditional fireplace let some part of the heat goes through the chimney. Sometimes people think that they will need several ethanol fireplaces to heat a big room, but in fact this type of fireplace is efficient to the point that you are able to gradient the amount of heat as higher or lower according to the size of the room.
Fact 3: Ventless Heating
One fact that is important to take in consideration it that an ethanol fireplace doesn’t need venting because it doesn’t make any smoke. Therefore, it’s a great solutions for people who cannot stand smoky environment, or if you don’t have the means to install a ventilation system.
Fact 4: Portability
If you move a lot, an ethanol fireplace is your ideal heating solution because it is portable and easy to transport.
 forum activity
