Login Error
Close
Expanding Your Mobile Home
by DoItYourself Staff
If you’ve lived in your mobile home for quite a while you could possibly be considering expanding your living space. If you live in a mobile home park, this might present a little bit of difficulty because of the limited space involved. Additional space can be a welcome change to a cramped or tight living environment. It is often advisable to seek out some mobile home financing before you commence any work.
Structural Considerations
Determining your particular remodeling needs also entails looking at the overall structure of your mobile home. In this type of home, you do not have the same structural support that you do in a house with a basement or more solid foundation. Supports may operate from the ceiling downwards while some mobile homes will be built without any type of structural supports at all..
Keeping the Floors and Walls Intact
When renovating your mobile home, make sure that any additions you add do not affect your flooring or walls in such a way as to weaken them. This is a primary consideration when doing any renovations of this type. If you should cause any openings in the walls, for instance, make sure you immediately repair them and fill them in. Not only is safety an issue here but such a repair is necessary in order to keep any pests from gaining entry into your mobile home.
Also remember any structural changes you make, such as “tearing down” a wall, can also affect the strength of the interior flooring. Therefore, make sure any repairs to secure the floors and walls are made or your efforts could be in vain.
Adding Outside Structures
Probably the safest way to remodel a mobile home is to add on structures outside the home itself. For instance, the addition of, say, a porch or carport can be included without infringing on the structural integrity of the mobile home. This inclusion can still look like it’s part of the mobile home although it’s best though to build it as a stand-alone structure so both buildings remain strong and secure.
Adding Space in the Interior
Since a lack of space is usually the reason for most expansion projects in mobile homes, a space renovation is generally the safest and most reliable interior modification one can make. An area can be cleared by merely removing a partition in the home. This is a nice alteration as the entire space can be opened up into one room giving a feeling of overall capaciousness inside the structure.
Mobile Home Financing
If you do undertake a renovation of your mobile home, you’ll probably want to procure some type of loan to add the intended improvements. Usually, you can obtain a loan if your home sits on a permanent foundation. Mobile home funding normally covers the appraised value of the home and any repair work you facilitate on the outside as well.
Whatever route you take as far as remodeling, just make sure you play it safe and research your options first before you get underway.
 forum activity
