FAQs about Palm Tree Seeds
It is definitely astonishing how a large palm tree manages to grow from tiny palm tree seeds. Yet, the wonders of nature are made to impress. Let us discuss a few basic aspects about palm tree seeds.
How Do Palm Tree Seeds Generally Look?
Palm tree seeds vary depending on the different palm tree since there is more than one variety to be found. However, generally they are rather spherical and a bit bigger than normal seeds. If this is your first attempt at planting these seeds, try to select palm tree seeds which are easier to deal with since there are various types, some of which may be more difficult than others.
How Can You Acquire Palm Tree Seeds?
Palm tree seeds can be bought from specialized stores and even ordered online. However, you need to pay special attention to the quality of such seeds. Poor quality seeds and old ones will not give you the results you desire. It is generally recommended that when possible, if you wish to start growing palm trees, you should collect fresh palm tree seeds yourself. In such a case, make sure to collect ripe seeds which do not feature a greenish color.
Do Palm Tree Seeds Have To Be Cleaned or Prepared In Some Way Prior To Planting?
Yes, it is important to clean palm tree seeds prior to planting. Some seeds have fruit and need to be cleaned, as otherwise they may rot or develop fungal problems. To ensure best results, make sure to clean the seed from the fruit, and it is best to wear gloves in the process. It is also suggested to soak the seeds, as this can greatly help to revitalize them and improve their properties for more effective growing. Try to soak them at least a day prior to planting them.
How Can I Check If The Seeds I Have Are Of a Good Quality?
For palm tree seeds to be of a good quality it is best that they are fresh. It is a general rule that fresh seeds are heavier and they remain intact when you try to pinch them between your fingers. Another way to check is to immerse them in some water. If some of the seeds float, then it is an indication that they are not as heavy and hence, are most likely to be old and practically quite useless.
How Should I Plant Palm Tree Seeds?
It is recommended that you start off by planting the palm tree seeds in a pot. This will provide them a better environment to germinate in the beginning stages. You can better observe their growth and the temperature they are subjected to. Besides ,they will be safer from bugs, fungi and other related problems. Then, they can be re-potted outdoors. It is crucial to water them regularly and with plenty of water. They need a considerable amount of humidity to grow well.
When Should I Plant Palm Tree Seeds?
The timing depends greatly on the particular type of palm tree you intend to grow, but generally, you will need about a year to move onto the transplanting stage.
