Faux Tin Ceiling Pros and Cons
Installing a faux tin ceiling can provide you with a number of benefits. However, there are also some drawbacks that you will need to be aware of. Here are some of the pros and cons of installing a faux tin ceiling.
Pros
One of the biggest advantages of this type of ceiling is the look that it provides. The look of a tin ceiling is very attractive and very sought after in the building industry today. It carries with it a very high-end look, so many people are going to enjoy it. If you are trying to sell your house, people will be drawn to this feature of the property.
Another advantage of using a faux tin ceiling is that it can save you money. This is going to be much cheaper than actually installing tin ceiling tiles on the ceiling.
Cons
Although many people like the look of tin ceiling tiles, when you go with a faux finish, it may not look that realistic. Some of the faux finishes out there do not look like the real thing and people will be able to tell.
Another potential problem with this type of finish is that it will require maintenance. Real tin is very durable and does not require much maintenance, but the faux tin ceiling may.
