Login Error
Close
Features to Look for in an Induction Cook Top
by DoItYourself Staff
An induction cook top uses the concept of electromagnetic field to heat and food. It is a recommended kitchen addition that helps to save on electricity bills since it uses much less power than conventional cook tops. Further, an induction cook top doesn’t put forth the risks associated with gas-fueled cook tops. However, purchasing an induction cook top might be a bit confusing for first-time purchasers. This is largely due to the wide array of induction cook top choices present in the market. However, the following guidelines can help you towards making a smarter, more informed choice when buying an induction cook top.
Energy Efficiency Ratings
Please note that the energy savings associated with induction cookware is its most critical feature. Induction cook tops are able to put forth considerable energy savings since they don’t lose any of the heat energy into the surroundings. However, the energy performance of every brand of induction cook top is bound to be different. The energy performance of such cook tops is reflected in their energy ratings.
Many of the energy ratings are preceded by symbols or abbreviations (grading benchmarks) that are endorsed by international, government or state-level authorities. Such cook tops definitely present a more authentic form of energy ratings. Further, if there is any confusion regarding the interpretation of such ratings, the precise meaning in terms of actual power savings can be easily cross-checked by conducting some basic search on the Internet.
Constructional Material Considerations
It is vital that you spend some time contemplating the various choices available in the induction cook top niche in the form of the construction material used. Please note that induction cook tops are prepared from materials that help to establish a magnetic field without conducting any heat to the outside. Thus, induction cook tops are commonly made from cast iron that is regarded as the most durable and efficient choice.
However, some brands manufacture induction cook top from blended materials. This includes the use of copper, glass and aluminum. These materials are conventionally not the best of induction agents. However, such cook tops have a more premium-looking exterior.
If you are looking for an induction cook top from a purely performance-based perspective, those made from ferrous materials like steel or cast iron are the best options.
Safety and Operational Features
Safety is assured in induction cook tops but there are some facets that need careful consideration. Ideally, an induction cook top shouldn’t get heated on the outside even if used for a long time. This is one the simplest and most authoritative features that define the performance of an induction cook top.
If the salesman is sure about the performance of the cook top in this regard, he should be willing to offer an actual demonstration and offer a warranty for the same. Further, the induction cook top tends to get heated much faster than conventional cook tops. Since no flame is visible in induction cook tops, a very dependable form of temperature settings is needed.
Thus, the heat adjustment controls in an induction cook top should offer systematic but easy-to-understand controls for adjusting the temperature. Many induction cook tops offer the convenience of predefined settings for some typical cooking requirements.
Installation Requirements
Induction cook tops need a typical kind of installation on the kitchen countertop. Unlike, conventional cooktops, it is vital to have a capable electrical supply point that supports the voltage demands of the chosen induction cook top. It is vital to ensure that the width, length and thickness of the induction cooktop surface are compatible with the existing countertop surface.
 forum activity
