Login Error
Close
Felt Rug Pad Purchasing Guide
by DoItYourself Staff
A felt rug pad placed under an area rug is an time-tested means of protecting both the rug itself as well as the wood or tile floor underneath it. Especially useful in high traffic areas, felt rug pads can extend the life of your area rugs by reducing wear and tear. If you have invested in high-quality, hand-made rugs, consider pads an absolute must.
To ensure that you are buying a quality pad that will protect your feet as well as your rugs, consider the following criteria before purchasing felt pads.
Tackiness
The first thing you want to consider is the “tackiness” of the felt rug pad material, which is what holds the carpet in place on top of the finished floor beneath it. You will want enough friction to keep the pad and rug from sliding even with dogs and children running over them.
Thickness
The second thing you need to consider is the thickness of the felt rug pad, especially if the rug is on the second floor of your home. Thicker rug pads will provide greater sound insulation as well as providing cushioning and warmth for your feet.
Considering these factors will help you make the right decision when selecting your felt rug pad.
 forum activity
