Fertilizing And Pruning Organic Goji Berries
Organic goji berries are hardy plants that you can easily grow in your own backyard. To ensure that your plants yield a healthy crop of fruit, make sure you understand the special needs of goji berries.
Applying Fertilizer on Organic Goji Berries
Goji berry plants do not really require fertilizer. However, if you want your plant to mature and produce fruits faster, then you may use fertilizer mixes. Find one that is organic and contains nitrogen compounds. This type of fertilizer will help your plant develop faster when used during spring time. However, you should not expect a lot of flowers or buds at this time of the year.
In midsummer, change your organic fertilizer to one that has phosphorous, but no nitrogen. This mix will promote the growth of flowers and fruits.
There are ways of pruning the goji berry plant.
For the first, allow the plant to grow wild and tall for 12 full months. Then give it one very thorough annual pruning. This will help it yield more fruits. However, many of the berries will be inside the thick foliage. Since goji berry plants have thorns, you must be very careful during this process.
In Asia, pruning is done regularly in order to keep the plants small. To be able to do this, your tree must have only one trunk, but many fruiting branches. All branches need to be approximately 2 feet long, and all new shoots should be cut and trimmed. The main advantage of this pruning style is that you will not have any problem when picking the berries. Still, keep in mind that you might have to compete with birds, deer and other pests who also want the sweet fruits.
Other Helpful Tips on Growing Organic Goji Berries
It is important to note that goji berry plants do not ilke soil that is soggy and wet. However, during the first few days of germinating goji seeds, you might want to keep the seeds underwater. Once you see leaves sprouting from the seeds, plant them in a container that has good drainage.
