Fiber Optic Landscape Lighting Guide
Fiber optic landscape lighting allows homeowners to light up their yards in a unique way. This type of lighting has been around for more than one hundred years, and is perfect for outdoor lighting because fiber optics are designed to light specific places extremely accurately.
This type of lighting is ideal for landscaping because it allows you to use lights for specific tasks and highlight particular areas of the garden. Another great thing about fiber optic lights is that they are safe to use around kids and pets.
Buying Guide
Buying fiber optic lights for the outdoors is not difficult to do. The first thing you should do is draw a picture of your garden and plan out where each light is going to be placed. Make sure you keep the picture straightforward so that when it comes time to go shopping, buying the lights will be simpler.
Before purchasing the lights, decide what look you want to create. Fiber optic lights are perfect for lighting up a garden or walkways. They can even be used to make elaborate designs in grass and on other surfaces.
The next step is to figure out where to put the illuminator. Experts recommend placing it in a central spot so that the lights are easy to manage. The illuminator is what sends light to the fiber optic fixtures throughout the yard. To ensure the light is dispersed properly, it's important to locate it in a large area. It's also a good idea to keep the cable lines no more than 40 feet from the illuminator. This is to keep the lighting even.
When you decide the best place for the illuminator, it's time to do measurements so you know how much fiber optic cable to purchase. You should compare the cost of long fiber optic cables versus shorter ones before going to the store. Essentially, the type of cable you need to purchase depends on what kind of lighting you want to create in your yard. Keep in mind that you'll need to buy extra cable for a service loop.
More Tips
Fiber optic cable has many different features available, including a color-changing feature. This type of fiber optic lighting is good for water areas.
Short fiber optic cable makes lights brighter, while long cable creates lower lighting effects. When shopping for fiber optic lights, make sure you purchase the right type of cable. Cables that are the same length create even lighting, while cables of different lengths create lighting with variations. More cables means more light. Illuminators should be placed 2 feet apart for the best results.
Proper planning ahead of time will ensure you save as much money on fiber optic lights as possible.
