Login Error
Close
Find the Right Computer Graphics Card for Your Gaming Needs
by DoItYourself Staff
There are a few things to consider if you are purchasing a new computer graphics card for your PC if you use it for gaming. This quick guide explains what you need to look for when purchasing the right graphics card. Make sure however before you purchase a graphics card that you are able to remove the old one from the motherboard as some graphics cards are soldered in.
Your Computer Processing Unit (CPU)
If your CPU is an older model then it may not be compatible with the latest graphics cards. Check the specifications of the graphics card before you purchase it and make sure that you will be able to use it to it's full potential with your computer.
2D vs. 3D
If you are using your computer more for 3D gaming than 2D you will need to purchase a graphics card designed for this purpose. These are usually more expensive.
The Graphics Processing Unit (GPU)
Each computer graphics card comes with it's own GPU. The speed of the GPU will depend on the specifications of the card. If your gaming involves intense graphics then you should consider purchasing a graphics card with a higher speed GPU.
Cost
Cost is always going to be an important factor when purchasing a new graphics card. When you have established your needs, make sure the graphics card fits your budget. There are many card manufacturers to choose from.
 forum activity
