cancel
Job type :
Zip Code :
community forums
comments
Finding the Best Cordless Tools For Your Needs
To find the best cordless tools for you, know exactly how you will use them. The latest advancements in battery-powered tools provide them with better ergonomics and more power compared to their corded counterparts. Consider these other aspects of a cordless tool before you buy.
Size of the Cordless Tool
The best cordless tools are the ones that you can easily carry and move around with. There is no use in buying cordless tools that are so big, they cannot fit into small spaces when you need them. Worse, if you do not have much space at home, bigger tools can be difficult to store. In the case of smaller devices, you do not want them to be so small that you always misplace them after use, or with parts so small that they are easy to lose.
Weight of the Device
Again, there is no use in having a cordless tool that is so heavy, you must keep it stationary. Choose tools that will be convenient to use. If you are working on home projects on a regular basis, select lightweight tools so that your hands, wrists, forearms and shoulders will not be strained while you work.
Battery Capacity
The main drawback in cordless tools is the fact that they can lose power if their batteries run low. For best performance, choose a tool that has a more efficient battery capacity. Right now, tools with lithium-ion battery packs work the longest with the best results
member comments
posted Aug 20, 2009
Interesting article. One of the problems with cordless drills is that more weight usually means better quality and less weight means cheaper. It's sort of a catch22. Those drills that combine the two are rare. I think that Makita has struck a good balance with their new drills. I've done some research here: http://www.bestcordlessdrill.net
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Painting Stylish Wall Borders
sponsored articles of the day
