Finding the Quietest Window Air Conditioner
Using a window air conditioner is one of the best ways to deal with the summer heat. In addition to keeping temperatures at a comfortable level, window air conditioners also purify the air to a good extent, which makes them perfect for those with breathing problems. However, air conditioners can be quite noisy. Fortunately, there are many air conditioners available today that operate silently. Here are some important tips when looking for a quiet air conditioner.
- One of the most important things to remember is that you should buy a unit that is the right size. This would require getting a unit that has a BTU rating appropriate for the room.
- It is advisable to get an air conditioning unit with a slightly higher EER, as it can help with reducing noise from the unit. This is also a more economical choice.
- Another important factor when selecting a quiet window air conditioner is to ensure that it has a variable speed fan and adjustable thermostat.
Besides these, you should check that all the parts are tightened down and that the unit is installed properly. This will eliminate any kind of vibration sounds and will keep the unit running smoothly.
