Login Error
Close
Fire Prevention - Using Household Appliances Wisely
by DoItYourself Staff
Fire prevention can be simple and stress-free if you follow some basic ground rules.
Electrical Cords
Make sure all appliances have fully functioning electrical cords; frayed endings or endings where the inner wire is exposed are unpredictable, and should be repaired immediately.
Checking for Danger
Inspect all electrical outlets frequently. Be sure there are no black or burned marks on or around the outlets, which indicate dangerous malfunction.
Go Professional
Have an electrician inspect and replace old or damaged outlets. Stripped or deteriorating wires may be lurking behind old outlet covers; hiring a professional to do a run-through and ensure outlets are functioning properly is well worth the investment.
Risk reducers
Turn off major appliances when leaving your home, especially coffee makers, toaster ovens, and space heaters. Particularly if you will be away for more than one day, unplug as many appliances as possible.
Power strips
Avoid overloading power strips. Overloading a strip with too many plugs dramatically increases the chances of a short circuit.
Bedtime safety
Never sleep with an electric blanket plugged in or turned on. Although it might be tempting, leaving an electric blanket on during the night can easily start a fire when the family is most vulnerable.
Accidents happen
Be prepared for accidents by investing in at least two smoke alarms to keep your household safe from malfunctioning household appliances.
 forum activity
