Five Advantages of Using a Worm Composter
Using a worm composter provides many benefits which other alternative composters do not. Worm composting, otherwise known as vermiculture, vermicast or vermicompost, leads to rewarding advantages to plants, gardens, lawns and the environment in general. The whole process of worm composting takes place in a bin, where the worms naturally manage to turn food waste and organic matter into a viable fertilizer.
1. Fast Process Leading to Concentrated Fertilizer
One very evident advantage of worm composting is that the fertilizer is produced much faster than other traditional composting methods. Thus, when fertilizer is needed urgently, the worms’ ability to produce it quickly becomes a very valuable feature. Moreover, worms produce fertilizer which is very rich in nitrogen and phosphorus, which makes the compost very concentrated. As such, worm compost should be used sparingly because of its high concentration of minerals. This also means that worm compost lasts for a long time compared to others.
2. Possibility to Produce Inside or Outside
Worm composting has the option to be done both in a closed environment as well as in the natural world. This naturally provides more options than other methods, and since it can be done inside, it can virtually produce compost all year round. On the other hand, composting methods which can only be done outdoors are necessarily dependant on the seasons. Moreover, even people who do not have a garden or a yard can perform this kind of composting, since it is not only limited to households containing an outdoors area.
3. Lack of Nasty Odors
If done properly, worm composting is virtually odorless. The concept of composts having a bad smell is widespread, but in this case the process can be done without the smells inherent in other methods. In fact, one has to simply not overload the bin with food and not allow the food to sit for too long. Allowing proper ventilation is also another aspect of achieving an odorless composting process. Make sure you keep the drain holes at the bottom of the bin unclogged, so that the bin’s contents do not get too moist.
4. Affordability
An important advantage of worm composting is its economical aspect. Virtually the whole composting process can be carried out without spending a penny. However, it is more worth it to buy the worms instead of going through the trouble of finding them yourself. Worm composting is essentially recycling, so you don’t even need a bin – you can use any old container you already have.
5. No Hassle Involved
Worm composting does not require any heavy lifting, making it ideal for the elderly and disabled as well as for anyone else. In fact, the weight of the bin and its contents will depend on what you choose to put in. Therefore, you are always in control of the whole process, and you may choose to stop adding material whenever you see fit.
Worm composting has various other benefits, but the five mentioned above are probably the most evident and important.
