Login Error
Close
Five Benefits to Using a Solar Garden Lantern
by DoItYourself Staff
Solar garden lanterns are becoming more and more popular as people embrace the benefits they provide as opposed to traditional lighting methods. As the name implies, these lanterns are powered solely through sunlight, which provides the energy needed for the lights to work. Garden lanterns are naturally perfectly situated to receive plenty of sunshine during the day, which can then be converted to lighten up your garden without the need for any electrical outlets. Solar garden lanterns thus have quite a number of benefits, which this article will try to summarize.
1. Save Money on Electricity
As is the case with solar powered devices in general, the main benefit is that you get to save money from electricity bills. Of course, they may be more expensive than normal electrical lights when you first buy them, but in the long run solar lights provide a cost-efficient solution to lighten up your garden.
2. Preserve the Environment
Installing solar garden lanterns will be another small but steady step to preserving our environment. In fact, using electricity means burning more fossil fuels, worsening the issue of global warming and plunging the planet in more environmental strife. On the other hand, opting to install solar lanterns will ensure that you will be getting your light from a free and natural energy source, while limiting environmental damages in the process.
3. Ease of Installation and Use
Solar garden lanterns are very simple to set up, and what’s more, you do not need to hire any electrician to get it all set. All you need to keep in mind is to install them in the place which gets the most amount of sunlight to maximize their effect. Since these are garden lanterns, you do not have to worry about plugging, electrical outlets, wiring or any other eyesore whatsoever. In fact, it would be counterproductive to install lanterns for your garden to look better, only to litter the scene with wires. Apart from being easy to install, solar garden lanterns provide design flexibility as they can be moved from one location to another without the need to rewire or add sockets.
4. Automatic Light Sensors
Solar garden lanterns come with the added advantage of having automatic, built-in light sensors which distinguish between day and night. Therefore, the lanterns will switch on of their own accord when the sensors detect a lack of light in the atmosphere. Similarly, they will switch off automatically once there is enough light available. Naturally, you may still switch solar lanterns on and off as you please, as you would do with standard electrical lights.
5. Resistance and Durability
While solar garden lanterns will be situated outside, you do not have to worry about damage resulting from bad weather. This is because solar lanterns are weatherproof, and will not stop functioning after heavy rain or wind because they are specifically designed for outdoors conditions. Moreover, no particular maintenance is required from the owner of solar powered lanterns.
If you want to make a sensible choice that will help conserve natural resources, consider installing a solar garden lantern. It will definitely make a great addition to your garden while saving the expenses involved in electrical lanterns.
 forum activity
