Login Error
Close
Five Concrete Patio Surface Materials
by DoItYourself Staff
Most homeowners want more than just a grey slab in their backyard and luckily there are many materials available to improve the look of a concrete patio surface. Decorating your concrete patio will not only give it more visual appeal, but could potentially add value to a property when it comes time to sell. Below are some options available to homeowners looking to create a concrete patio where they can feel proud to relax and unwind.
Stamped concrete
Stamped concrete involves impressing patterns and textures onto the concrete before it is fully dry. Stamps are now available in a large variety of patterns and can be used on patios, driveways, swimming pools or any other concrete surface.
Concrete stencil
A popular option among homeowners looking to brighten up their concrete patio is a concrete stencil. Easy to install, this method of decoration involves the use of high quality paper which cuts into virtually any design. Some of the more popular stencils are made to look like brick, stone or tile adding an authentic element to any concrete patio.
Concrete pavers
Concrete pavers are a hugely versatile product. An almost unlimited number of colors and textures are available as well as hundreds of different shapes and sizes. Concrete pavers are one of the easiest surfaces to install with 90 percent of the work involving preparation of the subsurface. The three most common types are tumbled pavers, which have rough edges and resemble stone or slate, bush hammered pavers, which boast a rough, stone-like finish and ground pavers, which are smooth to the touch and bear similarities to granite, marble and terrazzo.
Exposed Aggregate
Exposed aggregate can be used for a driveway or concrete patio and is made up of small stones and pebbles that create texture within the cement. It adds a different dimension to the usual smooth finish of concrete patios and can be colored for a decorative finish. Generally, installing exposed aggregate is not viewed as a DIY job, although with a bit of confidence, it is certainly possible to create an attractive exposed aggregate surface. The decorative stone can either be added into the concrete mix or directly onto the surface of the concrete providing a slip-free, durable finish.
Acid stains
Acid stains can transform grey, lifeless, concrete patios into virtual works of art. It is a good option for homeowners, as it does not need to be installed by a professional, but good preparation is key. It is vital that the surface is ready for the stain, so avoid rushing straight in. Think carefully about how you want the concrete to look because you will only have one chance to get it right! Sadly, it is impossible to know exactly how the finished product will come out since every surface is different and accepts stains differently. Indeed, the same acid stain can produce an entirely different result on two seemingly similar concrete slabs. That's why it's important not to get too caught up in trying to pick an exact color. Instead, choose a stain which will complement the area even if it comes out a little lighter or darker than expected.
 forum activity
