Five Things to Know About a Natural Stone Veneer Fireplace
A stone veneer fireplace can enhance the beauty of your home and provide a place where you can enjoy your free time with family and friends. You can choose to relax, dine together, read a book, watch television or tell stories in front of your fireplace.
1 – Ancient Use
Keep in mind that the natural stone fireplace is really one of the oldest fireplaces ever built. It originated hundreds of years ago. The stone veneer of a fireplace helps the construction to last for a long period of time.
2 – Resistance
Natural stone veneer fireplaces are renowned for their resistance and durability. They do not need a lot of maintenance to retain their beautiful appearance. Such a fireplace can be installed both in an indoor or outdoor environment. If you decide to install the natural stone veneer fireplace in the patio, you can put your mind to rest that the weather will not damage the fireplace. Natural stone veneer is different from cultured or cast stone veneer because it will not lose its beauty if it breaks or gets chipped. Apart from being resistant to weather, the natural stone veneer of a fireplace is resistant to fire and heat as well.
3 – Cost
Natural stone veneer fireplaces cost less than whole stone fireplaces. This is an advantage if you would like to save money and have a fireplace that resembles the traditional type. People who look at the fireplace will not notice that the outer stone-looking layer is veneer, but they would think it is actually a whole stone layer.
4 - Weight
In terms of weight, natural stone veneer is lighter than whole stone but they are equal in strength and durability. There is no need to worry that you will not find the same choice of styles and colors as whole stones. Keep in mind that stone veneer is made from authentic stone so you should have the same choices in style and color.
5 – Selection
Make sure that you choose tough stones to make a veneer for your fireplace. Do not select slate or any other soft stones because these can easily fall to pieces. However, granite and limestone are ideal to make veneer out of, and you can select metamorphic rock with a high density as well. Do not use mortar but replace it with fireclay. This is because mortar tends to crumble when repeatedly exposed to fire and heat.
You are also recommended to use fireclay instead of mortar because the joints of the stones are relatively small. Apart from this, unlike mortar, fireclay becomes more glassy and less porous every time you light up the stone veneer fireplace.
Make sure you follow all basic safety procedures when you are handling stone veneer or fixing it on your fireplace. For example, always make use of a diamond saw blade if you want to cut or shape your stone veneer correctly. You must wear a pair of safety glasses as well, in order to prevent any tiny pieces of stone veneer from entering into your eyes.
