Login Error
Close
Five Tips to Paint a Two-Tone Wall
by DoItYourself Staff
You can add a sense of drama, style and depth to any room in your house by learning to paint two-tone colors on your walls. Your children’s room can become instantly fun and colorful with bright two-toned paints. The sitting room can turn into an elegant area with subtle hues and your own bedroom can look bigger with the right application of paints. Here are some tips on how to paint a two-tone wall.
Considering the Design
Before you choose your paints you need to be sure of the room and the design. If you are considering a children’s room then opt for fun designs where you can stencil on bright colors in creative shapes on a basic background color. You can also have fun with your children and take turns in splashing color on to the walls to make the process and result fun. For a more grown up environment try and choose a design that is more subtle. You can have one color blending into another gradually, or you can have a clean dividing line separating two contrasting colors.
Color Options
Candy colors are great for young children’s rooms. Sunny yellows and oranges, bubble gum pinks with purples can create a happy room. In your more formal areas you can create a classic look with a black and white wall. You can use subtle rose pink blending into a deeper pink for a romantic period look. Use lighter shades to give an illusion of space and darker ones to make a stark room cozy. You can use cooler colors like blues and greens for your bathroom. You can even opt for paints that are similar in color, but have different finishes like matte and gloss or create textures with brush strokes. The top part of the wall should always be lighter since it will make the room look longer.
The Process of Painting the Two-Toned Wall
After you have decided on the color and design start with the lighter shades. Use masking tapes for areas you don’t want painted and cover anything that cannot be moved out of the room. You can simply paint two bold colors with a clean dividing line or subtly blend in two colors. You can swirl your paint brush to create textures or use a stencil and create shapes and patterns with a darker color. You can also use a sponge to create an interesting effect.
Things to Avoid
Try and get a dividing line as neat as possible and avoid the paint from bleeding into one another in an unattractive fashion. If you are painting two bold colors or contrasting colors next to each other than wait for the lighter shade to dry completely before you attempt to paint with the other shade. Always test the paint and design on a small patch before you commence painting your two-toned wall.
Finishing Up
You can add creativity to any room by painting a two-toned wall. After finishing painting you can unmask the tapes and put any fixtures back that you may have removed during the process.
 forum activity
