Fixing Common Problems Associated With Wall Gas Fireplaces
A wall gas fireplace is a wonderful way to add warmth and coziness to your home during the cold season. Traditional fireplaces tend to pollute the inside of your home with soot and ash, which makes cleaning up after a traditional fireplace an added chore. More modern gas fireplaces have replaced the more traditional types since they are much easier to use and more efficient. Wall gas fireplaces, however, have their fair share of complications.
Advantages of a Wall Gas Fireplace
Unlike the traditional types of fireplaces, a wall gas fireplace will not pollute the inside of your home. This makes it easier for you to maintain as you will no longer have to worry about cleaning up after the fireplace. The heat that a gas fireplace produces lasts for a long period of time and does not die out. It is much safer than using logs or wood and burning them yourself with the use of gas and matches. You will no longer need to supply logs or wood sources in order to fire up your wall gas fireplace. Some types come with remote controls, so they are very safe to operate since you do not have to go near the fire. Wall gas fireplaces also do their job in conserving energy.
Safety Before Repairing
Before performing any form of repair, make sure that the gas source is turned off. Also keep this tip in mind for when you do not need to use the fireplace so that your family is safe from any unwanted accidents or gas leaks. A gas leakage is very dangerous to your health. When inhaled, it can cause dizziness, nausea, or difficulty in breathing. Since gas is colorless, you will not be able to detect it easily. So be sure to make it a habit to shut off the gas source when you do not need your fireplace.
Problems and Repairs
One problem you may encounter with a wall gas fireplace is its refusal to turn on. A reason for this is a blown pilot light. To fix this problem, first open the fireplace vent. Examine if the little flame there is lit or not. If the flame is out, you will have to light it manually with a match or lighter. Once lit, try turning on your fireplace again. Another problem is if the main burner does not turn on or does not operate properly. This may be a sign of weak wiring. Check the wiring of your gas burner as well as the voltage that is provided. They should be compatible. If not, you may have to rewire your gas fireplace system. You might also experience trouble with the thermocouple. This part of the fireplace provides the mechanism that regulates the heat provided. Check to see if the thermocouple is loose. If so, simply tighten it to make sure it is securely in place.
