cancel
Job type :
Zip Code :
community forums
comments
Flatwork Concrete
Installing flatwork concrete for your driveway is a good way to make your driveway last a long time. When done properly a flatwork concrete driveway can last you up to 30 years. These few tips may help you achieve the lifespan you’re looking for
  • Flatwork concrete is very sturdy but is very prone to cracking when it’s stretched or bent. To help minimize this you should make sure that it’s constructed properly with expansion joints and reinforced steel. Also, to help avoid stretching, you need to make sure your contractor has properly compacted and graded the soil.
  • The control joints are also important to help control the effect drying has on flatwork concrete. The joints should be at 15 feet intervals at the most and should be at least ¼ as deep as the slab.
  • The reinforced steel will help provide strength to the flatwork concrete.
Important Lessons for Flatwork Concrete
There are some important items that should not be forgotten.
  • Make sure the flatwork concrete is mixed properly. If you ordered 4,000 PSI make sure you check the slip. If it says something less you should send it back.
  • Don’t pour the concrete in very hot weather that’s near 90 degrees. Wait for a cooler day or have it poured in the morning.
member comments
Related Articles
Make a Statement With Brick PaversMake a Statement With Brick Pavers
This article shows how to make a statement with brick pavers... read more
Driveway Paving Installation Steps
Driveway paving involves covering the ground leading into a home with a hard surface, which... read more
Driveway Landscape on a Budget
When you are staring down a blank driveway it can be disconcerting but a driveway... read more
articles we like
Granite Countertop Colors
Black is the most common granite countertop color. This has led to the perception that... read more
Solid Surface Countertops
Solid surface countertops are made from surfaces manufactured with a blend of resins and mineral... read more
How to Create Wealth with Real EstateHow to Create Wealth with Real Estate
How do you envision retirement? Do you see yourself working until you''re well into... read more
sponsored articles of the day
diy centers
