Login Error
Close
Flipping Houses: Common Mistakes to Avoid
by DoItYourself Staff
During a buyer’s market, flipping houses has become an exciting and profitable trend.  Flipping houses isn’t something that you can just run out and do; it’s important to learn and avoid some of the most common mistakes of flipping houses.
Mistake Number One
House flipping isn’t something you need to take a class on, but do your research and do it well. The most important thing an investor needs to do is to bulk up on their real estate knowledge.  The more you know about real estate the better you’ll do.  Researching can be as easy as sitting down at a computer and reading magazine articles and books.
Mistake Number Two
What many people do not realize is that real estate investment is like starting a small business.  Even small mistakes can ruin your savings and investments.  When first get involved with house flipping you need to look at as starting a business, so you need to cater it to your needs.  By starting your investments as a business, you can keep from ruining your private property if there is a problem with the house flipping business in the future.
Mistake Number Three
Getting insurance is incredibly important in any real estate investment.  But insurance policies can be confusing and obscure.  It’s very important for you to read the policy carefully before signing, and if you aren’t sure you understand it, find a professional who will explain it and show you the best policy for your needs.
Mistake Number Four
Starting without a plan is a bad idea. Everything worth anything needs careful planning.  You need to sit down and outline a plan that will point in you the right direction of your wants and needs and keep you on track.
Mistake Number Five
Everyone needs a budget.  If you fail to decide what you can and can’t afford before doing any transactions you may end up losing money.  Once you know what resources you have available, you’ll be better able to decide what real estate works for you, and what’s outside of your reach.
Mistake Number Six
Before you make any commitments or transactions you need to know what the needs of the property are.  Houses can hold many hidden repair needs, that often cost much more than carpeting and painting. An important part of flipping houses is to make the property more appealing, so if your budget is tight huge repair bills will only lose you money and time.
Mistake Number Seven
Never get involved in a business venture with strangers. If you’re going into this venture with other people, it’s a good idea to really know those people well.  If you don’t have a strong team surrounding you, or a good relationship with those people, your venture could fail due to the actions of those other than yourself.  Your team isn’t limited to just other investors, but bankers, appraisers, real estate agents and others.  If you can’t count on one or any of them, then don’t do any business with them.
Mistake Number Eight
Once you’ve done all of those things, you need to put the whole works into motion.  If you’ve done one or any of the things listed above, but don’t start a transaction, you’ve wasted your time.  You can’t make money without doing the work.  While it might seem a bit daunting, once you get started the benefits while keep you exhilarated through the whole process.
 forum activity
