Foam beds are much different than a typical mattress. This is because a foam bed does not have springs; the foam mattress contains what is known as memory foam instead.
What Are the Pros and Cons of Foam Beds?
There are a few pros and cons to whether or not to get foam beds. These are outlined below:
1. The weight of your body is evenly distributed. This helps in back aches, neck aches and more.
2. This also allows for less pressure on certain spots that might otherwise have more stress.
3. The movement made on one side of the bed does not affect the other side of the bed. This is good for those who have a partner that is restless.
There are some drawbacks associated with the foam beds as well. The main complaint is people sometimes feel hot when sleeping on these mattresses. Some who suffer from hot flashes cannot lay on such a bed.
Questions of a Do It Yourself nature should be submitted to our
