Four Elegant Marble Bathroom Accessories
Though marble can be pricey, adding a few marble bathroom accessories can give your space class and elegance without the price tag.
Vanity Tops
The fastest way to add an elegant touch to your bathroom is with a marble vanity top. If you have a few hundred dollars to spend on renovations, you can find a marble vanity to match just about any décor. They are sturdy, easy to install and can last a lifetime. Shop around at different specialty bath supply stores and showrooms to find one that will work for you.
Sink Inlays
A marble sink inlay will add a lot to your bathroom. An inlay is a more affordable option than having an entire sink made of marble. No one will know it’s an inlay but you. You can find these sinks online starting at $160.
Soap Dish
The soap dish is an accessory that everyone who walks into your sees—and hopefully uses! It is also an inexpensive accessory that you can splurge on. You can find basic sink side dishes for as low as $50 and wall mounted soap dishes for as little as $100.
Accessory Kits
If you like the idea of marble in your bathroom but can’t afford to add a lot of it, consider a marble accessory kit. These will generally have the sink side soap dish, toothbrush holder, tissue box, lotion pump, tumbler and/or wastebasket. Purchasing a kit will give you a uniform look throughout without overdoing it.
