Four Mobile Home Roof Repair Tips
A mobile home roof can suffer damage due to many reasons and one of the most common is excessive weather conditions. The type of roof and the amount of damage that a mobile home has will determine how much repair work can be carried out personally. Here are some tips on repairing your mobile home roof.
Tip 1- Go to the Professionals
Bring in contractors for estimates of work. This will give you a framework for the amount of work that needs to be done, what process should be followed and how long the repairs will last for.
Tip 2- Can you Repair it Yourself?
If your mobile home roof is made from asphalt, the repairs will need to done by a professional. This could be a caretaker who might be located on a mobile home park or, alternatively, by an independent contractor. If there is a lot of damage, you might need to consider some form of mobile home financing.
Tip 3- Be Specific
If the roof is made from acrylic elastometric covering, this will require two coats of roof coating. There are also different types of roof coating which vary in price so always make sure the correct type is used for your individual needs.
Tip 4 - Fill in Holes
For bigger leaks, use glass fiber or melted plastic to repair the holes and then apply silicone sealant. When the holes have been covered, apply a layer of roof paint for additional protection.
