Login Error
Close
Four Options For Fixing A Failed Window Seal
by DoItYourself Staff
When your window develops a cloudy film between the panes, you have a failed window seal. This can happen to double and triple pane windows, and it can lead to a loss of insulation in your home. There are a few different ways to address the problem of a failed seal.
Replace the Window
If the seal is really bad, you can replace the entire window. Depending on the type of window, this may require the help of a professional. However, if it is a regular double-hung double pane window, it is a generally easy installation.
  1. Remove the trim molding.
  2. Unscrew the window frame from the sills.
  3. Remove window.
  4. Scrape any caulking left on the sills and frame.
  5. Lay down new caulking and place new window into frame area.
  6. Screw window into frame.
  7. Seal any holes with insulation and caulking.
  8. Replace trim.
Replace Glass
Another option is to remove the window panes and have the glass reglazed. For this, you will have to take the panes somewhere for professional reglazing.
If the seal is not leaking badly, you can have a glazier come to your house to do the job all on site.
Fix the Seal Itself
There are ways that you can fix the seal itself with the use of a specialty tool. Install a valve and and expel the moisture from between the windows, making a seal again.
While this is also usually done by a professional, it can possibly be done cheaper than hiring someone to reglaze the window.
Do Nothing
This might sound like a lazy way out, but if you live in a mild climate without extremely high and low temperatures, then you probably don't need to worry about the seal.
These windows are designed to keep the weather conditions outside to help with heating and cooling efficiency. If you live in an area where that isn't a problem, the you will not need the seal to work anyway. You will probably never notice a difference, with the exception of a little moisture build up once in awhile.
 forum activity
