Four Quick Automotive Engine Fixes
by Dave Donovan
In America, the automobile is king. From the time we were kids playing with Matchbox™ and Hot Wheels™ cars, our wheels are our pride and joy. But not everyone has what it takes to be a tried and true grease monkey. For some of us, the major automotive work is best left to professionals. But, you don’t have to be helpless when it comes to your car. Here are four easy and quick automotive engine fixes that will help you get through in a pinch.
#1 – Squealing Belts
When you start hearing an ear-shattering high-pitch whine emanating from your engine, that’s a sign that your belts are starting to go bad and will be needing replaced soon. The key word is “soon,” meaning not “now.” Pick up a can of aerosol belt dressing and spray it directly on the belt (while the engine is running) and that squeal will be silenced. This is a temporary fix, however, so plan on having your belts replaced in the near future.
#2 – Clicking Engine
When the engine is clicking, this often is an indication that the oil is low. Check the auto’s oil level after it’s been resting for a while. If the dipstick reads low oil or “add a quart,” add enough so it reads full.
#3 – Key Won’t Turn
If you attempt to start your car and the key won’t budge, there are a few things that may be the cause. It may be that the key is worn down. If you have a duplicate, give that one a try. If that still doesn’t work, then the steering wheel may be turned too tight. Try turning the wheel one way and then the other way. Then try turning the key. Once the wheel is loosened, the key should turn and the engine should start.
#4 – Engine Won’t Crank
If the key turns, but all you hear is a clicking noise, it may be that your battery is dead. Turn on your interior light. If it comes on, try starting the engine again. If the light dims while you are trying to start the engine, then the battery doesn’t have enough voltage to start the car. If the light stays brightly lit, check to make sure your car is in park. Otherwise, you will have to have your car taken in for service as it may be a larger problem.
