Four Tips For Using Fiber Optic Cable Connectors In Your Home Networks
If you are obsessed with home entertainment and want to set up a network in your home which will give you a professional performance with minimal complications, fiber optic cable connectors are your best option. Compared with copper cables, fiber optic is by far the better option for two main reasons. First, fiber optic cables are immune to electronic noise and electromagnetic interference, and secondly, it has a wide availability of bandwidth compared to copper wire. More information at a faster rate can pass through a fiber optic cable than a copper wire, which would mean both thinner and less cables are needed. Thirdly, information is not lost when traveling a long distance through a fiber optic cable, as it is transferred in the form of light pulses. Unfortunately, fiber optic is still not widely used, especially at home, but its practicality means that the demand for such cable is always increasing.
1. Computer Network
When people want to set up a PC network in their homes, most go for Wi-Fi network, but this has some draw backs, mainly security. If all your points are stationary, and you will not be using laptops at different and random spots around your house, fiber optic will be a much better option since no one will manage to connect to your connection and use your bandwidth. Nor is it as easy to tap as it is with copper wires. The cable is passed the same way as copper cables are, with the advantage that you can take the shortest or more convenient route without any worry of interference, even if you are bundling up the fiber optic cable with other cables. And the biggest advantage is that since the cable is made of glass and information is passed using light pulses, there is no worry of grounding the fiber optic cable, not even from lightning.
2. Television
An optical fiber cable can be used to transfer audio signals from a DVD player to another component, and if you have a TV that supports fiber optic connectors, they can be connected directly to it, giving increased audio and video quality. In some areas, cable TV suppliers are also changing to optical fiber cables to provide HDTV.
3. Home Theater
Digital optical cables can be used in high quality surround systems, also known as home theaters to connect sub-woofer to receivers and also to digital audio cable. In such connections, the last thing you want is electronic interference, which will result in a background humming. Fiber optic connection will make sure this doesn’t happened and your sound quality remains at very high standards.
4. Gaming
If gaming is your thing, connecting your console to an HDTV using optical cables will give a heightened experience of video gaming, thanks to its clear image and sound transfer.
What is holding fiber optic cable connections back from being a felt presence in our lives so far is not the lack of technology as the cable is concerned, but the lack of technology and high speed compatibility of other components. A general upgrade of all home technology is needed for fiber optic to be the only available connection, and although slowly, many modern game consoles, PCs and televisions are all part of the effort to become a faster data transfer unit that can support optic connections.
