Rope lights are not only easy to install, but are also affordable, green, and a versatile option to consider when purchasing lighting for your home or outdoor space. Below, you will see in further detail as to how rope lights are easily operated, inexpensive, extremely versatile, and eco-friendly.
Easy Operation
Rope lights can easily be placed and operated within your home or outdoor area. The only task required of you will be to place them in the desired area and plug the lights into an outlet. The rope lights are also very bendable thanks to a flexible plastic in casing the lights, so shifting or moving them entirely will not be a problem for you. Additionally, you can purchase a foot on and off switch to make operation of the lights even easier.
Affordable and Versatile
First, the price of the lights can easily be placed into your budget. You can find rope lights as inexpensive as $10 per square foot at home improvement stores or through on-line websites. Second, in addition to be affordable, the lights can be placed almost anywhere. You can shape the lights around decks, patios, fixtures, under cabinets and pretty much anywhere else. Also, while the standard rope lights come in a traditional clear casing, they also come in many different colors, light patterns, and effects that you can choose from.
Greener Lighting Solution
Using rope lights, especially ones with LED lights, is a good way to conserve energy and be eco-friendly. LED lighting, in general, consumes around 20 percent less energy than incandescent lights. Moreover, being that rope lights were designed as accent lighting, the energy they output is minimal because the lights are overall smaller in size and require less energy to function. So, instead of using your incandescent bulbs to light your entire living room, for example, you can use rope lights to illuminate your entertainment unit, desk, or even your lounging furniture instead. This will save you a good amount on your energy bill in addition to being more friendly to the environment.
Questions of a Do It Yourself nature should be submitted to our
