Fresh Block Paving Designs
There are plenty of ideas to choose from when it comes to block paving for your patio or driveway. There is a set of commonly used patterns that can be freshened up by adding borders in a contrasting color. With more intricate patterns, you can also come up with your own internal pattern using smaller concrete blocks. The same types of paving blocks can be used for standard-sized driveways or patios; be sure to take accurate measurements of the length and width of the entire area to be paved.
Stretcher Paving
These paving blocks are laid out in the same pattern as traditional red brick used in buildings. The end joints of two square blocks meet in the middle of the one below it, and this is repeated through each row. Try inserting a paving block in a contrasting color or texture in alternating rows, such as every third row or every fifth row.
Basketweave Paving
This pattern is accomplished by placing two narrow rectangular paving stones together at a time, then adjoining each pair together with the seams facing the opposite way. Try selecting every fourth vertical or every fourth horizontal block and install a block in a lighter or darker color. You can also create square or triangular panels with the same technique and varying the spacing. Mixed colors is one of the most commonly used variations on basketweave block paving.
Herringbone Paving
There are two popular herringbone patterns; one that places single paving blocks end to end, one at 90 degrees and the other at 45 degrees. 90 degree paving block patterns have a pattern that looks like stair steps. An intricate idea for this is to block out certain snaking rows and pave them with another color; try one with a smoother and glossy texture to make it definitely stand out against the rest of the block paving. Try the same with single alternating blocks in a 45 degree herringbone pattern. or roughly 1.9 to 2.3 inches.
Diamond Paving
The paving stones for this pattern are quite similar to mosaic tile, with the same small squares stacked together, just without the mesh or fabric backing. These are more time consuming and detail heavy to install than other patterns, but the creative possibilities are worth the effort. Block out a design for your diamond paving on a piece of graph paper beforehand, using one or more colored pencils to designate which squares will be which color. Using this method, you can create overlapping square, octagon, triangle, or even circle patterns. These shapes can be combined in any way you can come up with.
Remember that less is more when it comes to your own custom design on diamond paving, and it is advised to look up some design principles for guidance. These include balance, line, symmetry, and form. When selecting your paving blocks, keep in mind the minimum depth of each paving stone designed for a standard residential driveway; this should be between 50 and 60 millimeters, or approximately 1.9 to 2.3 inches. Any of the described patterns should include paving blocks that measure about 7.8 inches long by 3.9 inches wide.
