Login Error
Close
Frieze Carpet Styles
by DoItYourself Staff
One of the hottest trends in the flooring industry today is frieze carpet. Frieze carpet presents you with several unique advantages over other types of carpet and it comes in a variety of styles. Here are a few things to consider about frieze carpet and why you might want to consider using it.
What is Frieze Carpet?
In order to understand whether or not you want frieze carpet, you first need to understand what you are dealing with. Frieze carpet is a textured carpet made of smaller individual strands. In order to construct frieze, the manufacturer takes several small carpet fiber strands and twists them together very tightly. This creates a look that is very similar to the old shag carpet that everyone is familiar with. While it may look a little like shag, it is usually quite a bit shorter than the shag everyone had many years ago.
Durability
One issue that you always have to be concerned about when buying carpet is durability. You want to know whether the carpet that you are buying will hold up under the traffic that you and your family will provide. While no carpet will hold up to everything, frieze styles have a tendency to hold up better than others. The construction of frieze is what makes this extra durability possible.
Instead of subjecting an individual carpet fiber to the wear and tear of foot traffic, you are combining several fibers together and twisting them very tightly around one another. This creates a spring effect and the carpet will keep bouncing back time after time. With that being said, a lot of it depends on the carpet fiber as well. If you are dealing with a nylon or triexta fiber, you will have better luck than if you are dealing with polyester. However, if you had to choose between polyester styles, the frieze carpet will hold up the best.
Trackless
With this type of carpet, you are getting what is considered a "trackless" carpet. This means that you will not be able to see tracks in the carpet like you would with other carpets. When you are dealing with a flat plush carpet, you will typically see footprints when you walk across it. When you vacuum, you will see vacuum marks on a plush carpet as well. With frieze, this may not necessarily be the case. When you walk across the carpet or vacuum it, the carpet will spring back up into place. Therefore, if you notice any difference, it will typically be a very slight one.
Hides Soil
This type of carpet also presents you with the ability to hide soil better. Since the strands are long, you will not notice dirt and soil in the carpet as much. This could be a good or bad thing depending on your opinion. However, the one thing that is for sure is that you will not have to vacuum as much to make it look good.
 forum activity
