Front Load Stacked Washer Dryer Unit: Pedestal Installation
Front load stacked washer dryer pedestals not only add balance and security to your washing machine, they can sometimes provide you with extra storage or a warming drawer. Many pedestals are built with drawers so the space isn’t going unused. On some dryer models the pedestal can have a tray that keeps clothes warm until you can get them put away.
Building your own pedestal isn’t a hard process, and with some handyman experience you can add drawers for extra storage if you choose.
Building a Pedestal
Pedestals can be made of wood or steel. First of all take the measurements of your front stacked washer and dryer. After doing that, ascertain the weight of the machine. Also include the washing capacity of the machine, which basically means, how much it weighs once you load your laundry into it. Once you are ready with the dimensions, it is time to decide which material you want for the pedestal. While planning the pedestal make sure that the length and the breadth of the pedestal are bigger than the actual base of the washer and dryer. This helps you to balance the machine well on the platform. Also make sure that the pedestal has wheels attached to it. This helps to increase the mobility of the machine. You will also want to decide if you are utilize the extra space by placing drawers in the base.
Pedestal Frames
For the base of the machine, it is advisable to build one which has only the frame. A pedestal with a solid base not only is difficult to maintain, but also hard to move. While the machine is working, it is better if it is kept away from a solid surface like that of a wooden base or the floor. Keeping the front stack washer and dryer on a frame pedestal also prevents mold from gathering underneath it, which tends to eat away the base.
Choosing a Model
When it comes to buying a front load stacked washer and dryer there are many options in the market. Make sure that you buy one which is made by a good company and also one which comes with a few years of warranty. Get your dryer and washer serviced regularly in order to optimize its function.
