Furniture Paint: What Type to Use
If you are looking for furniture paint, you will have a few different options based on the material you will be painting. In most cases, the best type of paint to use for wood furniture is an oil-based enamel. This type of paint will adhere to the surface well and it will also stand up to the wear and tear that furniture tends to get. Before you paint, sand the surface of the wood to create a smooth surface, and then use an oil-based primer as this will help the paint stick.
If you are painting metal furniture, you should also use a primer. With this type of furniture a latex paint or an oil-based paint would work best. If the furniture is made out of plastic, a spray paint that is designed to adhere to plastic is your best bet.
